Use this task to view the default topology IP address for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Mgmt.
- Select the TopologyIp tab.
TopologyIp Field Descriptions
Use the data in the following table to use the TopologyIp tab.
Name |
Description |
AddrType |
Shows the IP address type for the topology IP. |
Addr |
Shows the IP address for the topology IP. |
InterfaceName |
Shows the interface name of the identified interface for the topology IP. |
InstanceId |
Specifies the interface instance for the topology IP. |
